    Upgrade to 3 point seat belts
    Upgrade to 3 point seat belts Empty Upgrade to 3 point seat belts
    Post by Guest Mon May 17, 2010 5:31 pm
    Since I'll be heading to junkyards to hunt down a replacement fuel tank for my 1965 Chevy Sportvan, I decided to finally upgrade the lapbelts to 3 point seatbelts. Are there any preferred models or styles that work best in these vans or is it more like grab what looks good and install?
    Can I use the original 2 mounts and just install a third on the wall above the shoulder? I looked through the forum and couldn't find the info I need.
    Thanks again,
    Mike
    Upgrade to 3 point seat belts Empty Re: Upgrade to 3 point seat belts
    Post by Guest Mon May 17, 2010 5:48 pm
    I'm going with Jeep Wangler belts in mine,set up right for the way you have to mount them in our vans.
    Number of posts : 1388
    Post by wideload Mon May 17, 2010 6:34 pm
    Number of posts : 801
    Post by panelmanrd Mon May 17, 2010 6:57 pm
    i got a set out of an 83 jag xj6 mounted about the same as
    wideload`s fieros
      Current date/time is Tue May 07, 2024 2:01 am
