    seat belts ?
    seat belts ? Empty seat belts ?
    Post by Guest Thu Feb 19, 2009 6:03 pm
    Howdy Smile
    My van doesn't have seatbelts and I was wondering how to install them.
    Any ideas?
    Number of posts : 7900
    seat belts ? Empty Re: seat belts ?
    Post by DanTheVanMan Thu Feb 19, 2009 6:41 pm
    You can get a 3-point belts and use the existing anchors. Just have to find a good spot for the shoulder harness ring to mount.
    seat belts ? Qr_cod10
    Post by Guest Thu Feb 19, 2009 6:54 pm
    Thanks, where are the anchors?
    Can't find anything in the shop manual.
    Post by DanTheVanMan Thu Feb 19, 2009 6:58 pm
    Driver's side should be just behind the outside/r seat mounting bolt. Same for pass. side unless you have/had a jumpseat. The you get to make your own mounts.
    Post by Guest Fri Oct 23, 2009 8:24 pm
    Any one have some pictures of this mod? I need to do this soon, I'm having to cram my kid in his car seat. That's not gonna last long at the rate he is growing.
    Number of posts : 2067
    Post by sasktrini Sun Oct 25, 2009 10:43 am
    In the absence of seatbelt mounting bolts, you can drill out a plate to take a bolt, weld a nut to the backside of it, drill a larger hole on the body / rib section so that the nut and plate will fit in there, and then weld the plate, flatside out to the body / rib section.
    That's the general idea anyway. Lap belts can be added by drilling holes, and using large washers under the floor to prevent the nut from tearing through a tiny hole...
    I hope that gives some ideas, and others have example pics.
      Current date/time is Wed May 08, 2024 6:54 pm
