    Seat Belts
    southern man
    southern man
    Number of posts : 486
    Seat Belts Empty Seat Belts
    Post by southern man Thu Sep 23, 2010 5:09 pm
    I have some two point belts I want to install. There is an 11/16 mounting bolt on the floor behind the passenger seat, about eight inches behind it and 4" from the doghouse, which I assume is for the belt, but no corresponding bolt or hole on the drivers side. The mounting holes for the belts on both wheelwells are smaller than 11/16 and while there are no bolts in either I'm guessing they're either 9/16 or 5/8.
    So where is the driver's belt supposed to mount to on the doghouse side? Can I use the rear seat mount bolt?
    Number of posts : 339
    Seat Belts Empty Re: Seat Belts
    Post by lectricman Thu Sep 23, 2010 5:35 pm
    I mounted my lkap belts down with the back bolts of the seat brackets.... It worked for me once, so why not again....
    Seat Belts 100_0759
    they kept me from hitting the windshield.... affraid
    southern man
    southern man
    Post by southern man Fri Sep 24, 2010 10:40 am
    Ouch! Painful just to look at it, but that's why I want belts.
    1963_econoline
    1963_econoline
    Number of posts : 8
    Registration date : 2010-10-07
    Post by 1963_econoline Thu Oct 07, 2010 4:56 pm
    not that it matters now, but i had the same problem and i tryed to mount it on the seat bolt but never could get it to fit right, so i just drilled a new hole and used the new bolts and washers that came with my seat belts, sorry about your Truck man...
      Current date/time is Sat Apr 27, 2024 1:10 pm
