Hey there,
Just picked up a 1965 E100. I have so many questions I don't know where to start.
Overheating: my 170 ci overheats when it is worked hard (driven up a slight incline ). brand new 160 degree thermostat. Mechanical fan. The radiator definitely has some holes but the fluid level is correct. It leaks when hot. Coolant drips from the holes when engine is warm. So i know hot coolant is making it to the radiator. An exhaust manifold leak is present (don't know if this would affect overheating). I searched all over this forum and couldn't find any threads showing overheating as a common problem. So i am assuming there is something wrong. Any thoughts?
Pod on the interior side of the left headlight: has an access door to a hollow space. Has a tube connected to the bottom of the chamber. What is this thing?
Thanks in advance for the responses. I don't know where i would be without this forum.
Colin
Colin
