    2nd Gen brake question
    Number of posts : 1046
    2nd Gen brake question Empty 2nd Gen brake question
    Post by VANagain Sun Jan 24, 2010 10:18 am
    I'm upgrading the "single" master cylinder in my 1st Gen to a "dual" from a 2nd Gen. I want to know which of the lines coming out of the master cylinder goes to the front brakes. I'm assuming it is the front one, because it has bigger threads.
    Do your front brakes use a bigger steel line too? All mine were 3/16" at the wheels so I'm just going to run that size line all the way.
    Number of posts : 1388
    2nd Gen brake question Empty Re: 2nd Gen brake question
    Post by wideload Sun Jan 24, 2010 12:11 pm
    VANagain these are some shots of my 68 parts van. The front brakes are fed from the rear reservoir on the master cyl. The two small lines leaving the junction block go to each of the front wheels and the larger line goes to the rear of the van. The junction block must be partitioned in the center because it's fed from each end by the two reservoirs of the master cyl.
    2nd Gen brake question 100_3519
    2nd Gen brake question 100_3520
    2nd Gen brake question 100_3521
    Post by donivan65 Sun Jan 24, 2010 1:32 pm
    That brake warning switch won't let you hook up the master cylinder wrong,,,,,,,
    2nd Gen brake question Repair35
    Post by VANagain Sun Jan 24, 2010 2:49 pm
    Thanks for the speedy response! I'm going to skip the junction block. Never had a brake light before on, don't need one now, I guess. I assume there is no pressure regulation going on in this junction block, it just watches for an imbalance from a leak.
    Post by donivan65 Sun Jan 24, 2010 3:03 pm
    ,,,,, all those Napa parts I listed are for a conversion not using a brake warning light switch junction block,,,
    2nd Gen brake question Empty 1st Gen adapter
    Post by VANagain Sun Jan 31, 2010 1:21 am
    Now I've got a question for you 1st Gen owners. Which way does the brass adapter go on the front brakes? Does the flexline connect above or below the hollow banjo bolt? My shop manual seems to show it above, but it seems odd to have the line going up that way.
    2nd Gen brake question Brake_10 2nd Gen brake question Brake_11 2nd Gen brake question Brake_12
    But, notice that my new brake lines have an elongated metal connector on that end, which makes it stick out further. I had hoped this meant I could leave out the brass adapter and just screw the flex line directly into the wheel cylinder. But I couldn't get it to screw into it, even though the threads looked the same. Have you guys ran into this? How did you handle it?
    Thanks,
    Post by donivan65 Sun Jan 31, 2010 11:13 am
    Where did you get that weird brake hose,,,,Carquest? Those threads are plain old American, both the same, and use a copper washer to seal them,so they require a flat shoulder on them. And the hose goes up so when you turn, the hose goes above the spring, otherwise it hits the shock, sway bar and spring. You ought to just go to steel braided hoses,,,,My Buddy Scott, in Texas, went to a place in Clairemont, Cal, and bought some. I am sure he would be glad to give you directions on how to get there........
    2nd Gen brake question Repair76
    2nd Gen brake question Nodoor52
    Number of posts : 1651
    Post by Scott Sun Jan 31, 2010 11:31 am
    I'll dig for the receipt, should be able to provide the part numbers too..
    Post by donivan65 Sun Jan 31, 2010 12:11 pm
    That's OK Scott, I have those numbers,,,,,,but the cool part was, you come from Texas to do some work in Los Angeles and you end up walking into a San Diego store and picking up those brake hoses and fittings,,,,,
    Post by donivan65 Sun Jan 31, 2010 12:30 pm
    ,,,,and besides,,,,,,VanAgain lives in Clairemont, California,,,,,,
      Current date/time is Sun Apr 28, 2024 6:06 am
