BZ BRAKE KIT QUESTION
Bear
Number of posts : 849
Post by Bear on Sat Jul 19, 2014 6:25 pm
anyone by chance got the instruction on the install of the BZ brake kit ? i got a set i would like to try too sell but useless with out install info
Jeremy Wynn
Number of posts : 46
Registration date : 2014-06-30
Re: BZ BRAKE KIT QUESTION
Post by Jeremy Wynn on Sun Jul 20, 2014 8:53 am
Bear wrote:anyone by chance got the instruction on the install of the BZ brake kit ? i got a set i would like to try too sell but useless with out install info
is this front or rear disc brake kit? I have no clue on the directions but might be interested in buying it from you if it will fit my 69 g10?
Number of posts : 11569
Post by donivan65 on Sun Jul 20, 2014 9:52 am
I am running these on my 65,,,,,,,you need to move the shock absorber,,,,,,we did put them on 2nd Gens also,,,,,,you use Chevy Nova rotors and Blazer calipers,,,,I have the directions,,,,,but these were made for Hot Rods,,,,,so the directions are not exactly correct,,,,,,M1Dadio made his specifically for our vans......
Post by donivan65 on Sun Jul 20, 2014 10:31 am
Bear
Post by Bear on Sun Jul 20, 2014 5:34 pm
SOLD THANKS
Number of posts : 1340
Post by wideload on Mon Jul 21, 2014 9:03 am
Here's a copy of the instructions that came with the BZ brackets that I have. Hope this helps.
Post by donivan65 on Mon Jul 21, 2014 10:08 am
....like I said,,,these brackets are for a Hot Rod,,,,,no way I would be drilling and tapping the steering knuckle holes and hope that it all stays together,,,,,and some of those spacers are not needed.....
Number of posts : 1732
Post by m1dadio on Mon Jul 21, 2014 6:20 pm
what Don said
m1D
Post by donivan65 on Mon Jul 21, 2014 6:42 pm
and that would be,,,,,, I used the original bolts in the steering arms,,,,,,,,and did not use those Support spacers for the rotors,,,,(I don't even know what that is),,,,,,double nutted the steering stop bolts to add support to the bracket.....
Post by wideload on Mon Jul 21, 2014 7:16 pm
Don are the instructions that I posted the same as the ones you have? My next question was to ask you what you did, but you just answered that. I got the BZ brackets before M1D came out with his and their still in the box with the instructions.
Post by donivan65 on Mon Jul 21, 2014 9:44 pm
Hey Mike, Thats the Official instructions that came with the brackets,,,,,I probably put mine on in the 90's,,,,,
so I probably got 100,000 miles on my brackets,,,,,,
    Current date/time is Sun Apr 22, 2018 6:56 am
