by donivan65 Thu Jan 07, 2010 9:44 am
I don't think I am right everytime,,,,,but i sure like to find the right answers,,,You might of found your problem,,,,if the tube is loose from the base,,,,it does not ground properly,,,,it becomes an open circuit. So when you take it off, resolder it,,,,just like you would with copper tubing,,,,and you tap those tabs on the retainer ring to rotate it until it unlocks the sending unit,,,,,,
