Today I've started to handle some rust issues on my 63 econoline van. One of the former owners has tried to repair the roof rail (I think this is the english word for it) by welding on some pieces and filling everything up with silicone sealant. After years in the sun, the sealant has dried out and water is getting stuck under this sealant, some parts of the roofrail are rusted trough, on two spots it has also rusted through the side of the roof. I've just spend a couple of hours peeling out the old sealant, now I just have to clean it up and try to weld the holes.
One of the former owners has also installed some kind of roof rack, existing of two pipes on the roof. Does anybody have an idea why they have installed it this way? I can only imagine they've used it for mounting stuff on the roof.
you can also see the rail on this picture.
And last, but not least, a final question about the sunroof. There is a sunroof mounted on the car, this roof is just to high for me to easily park the car in my garage. I always have to make sure there is some dead weight in the back of the van to drop the rear of the van to get enough clearance. I also think this roof is installed in a bad way, it's simply screwed in and then made waterproof with some sealant.
I'm thinking of welding the gap, but I'd really like to mount a flat sunroof. Does anybody know where i can get one of these. Or is it easy to modify an exising roof from another (modern) car.
I hope you can catch the drift of my story, my english isn't perfect so...... anyways thanks for checking it out, I hope to get some reactions.
Greetings from Holland, Ron.
