+6
wacko
gp70
PolarBear2
10 posters
    King Pins & Bushings
    ChevyVanMan1
    Number of posts : 425
    King Pins & Bushings - Page 2 Empty Re: King Pins & Bushings
    Post by ChevyVanMan1 Thu Sep 24, 2009 12:01 pm
    Although I had brass fitting on my 67 Econo's king pins they still wore out and needed a machine shop to bore and campher (if that's the right word). I'd try the Delrin fitting because it is a very tough form of nylon. However, since std wheel bearing grease will eventually disolve plastic I'd only use the Delrin bushings with White Lithium Grease.
    Good luck, please tell us what works for you, thanks!
    Post by Guest Thu Sep 24, 2009 2:55 pm
    i have gotten a few sets for diff vans from carquest
    part # carquest # CCH 8494N nylon
    carquest # CCH 8494B bronze
    last set i bought a couple yrs ago was 43.78 + 6.00 frieght(special order)
    have gotten bronze every time, and usually a day away to get em there... but
    each time sent both spindles and the new pin kit to my local machinist who "hones" out the spindles and presses the bushing into the spindles for me.. the pins fit GREAT , and would slide right in "like new" every time was around 30 bucks to the machinist to have the pair done and ready to install ..
    good deal IMO
    LOTS of grease.. and twice a yr grease em up again is how i do it
      Current date/time is Sat Nov 16, 2024 2:28 am
