I need to remove the ignition switch on the dash to check it out, as I'm having occasional starting problems again, and all the other component of the starting system checked out okay [i]this time[/i]. I've had times when I turn the key and nothing for three times, take the key out, stick it back in, turn it and it starts. Or it will start ok, the next time it won't, the time after that it will. The ignition switch looks like it might be the original one from 1968.
I know there is a ring on the outside with notches on the side, like where you would put a spanner wrench and I assume that is what is holding the switch to the dash. Before I start turning it, can anyone confirm I am correct and that it is a right hand thread to remove it?
