    Removing ignition switch
    dulcimerbob
    dulcimerbob
    Number of posts : 115
    Removing ignition switch  Empty Removing ignition switch
    Post by dulcimerbob Sun Feb 23, 2014 8:15 pm
    Can someone tell me how to remove the ignition switch from my 65 ? I need a key and can take it to a locksmith and get one done for 10.00 . I want to remove the whole switch as I have no key to remove the tumbler.
    Thanks
    Number of posts : 12246
    Removing ignition switch  Empty Re: Removing ignition switch
    Post by donivan65 Sun Feb 23, 2014 9:48 pm
    The only way to get the switch out is unscrew the bezel,,,,the only way to get the bezel off is remove the cylinder,,,,,the only way to remove the cylinder is to have the  key, put a paper clip in the hole and turn it counterclockwise to unlock it,,,,,,,maybe you can remove a door cylinder and if it uses  the same key as the ignition, you can get one made,,,,,or a locksmith can pick the lock so you can turn it so you can remove the cylinder,,,,,,,or usually you have to drill and destroy the cylinder to remove the switch and get a new one,,,,,,and put down your location.......
    Removing ignition switch  Ford_i10
      Current date/time is Fri Nov 22, 2024 4:43 pm
