    A108 Side Door locking mechanism trouble
    waltreid
    waltreid
    Number of posts : 5
    Registration date : 2023-02-18
    A108 Side Door locking mechanism trouble Empty A108 Side Door locking mechanism trouble
    Post by waltreid Sat Aug 17, 2024 12:33 pm
    Self inflicted wound here. I just acquired a 1968 A108 Window van that Im working through the issues. Today I popped out the side cargo door lock cylinder so the locksmith could determine the key. Got that handled alright but now, the door latch mechanism does not deploy in the handle down position. I cannot determine what happened or if somehow I damaged the rods. No matter what position the handle is in, the top and bottom latches do not emerge. I cannot figure out (maybe it's the Houston heat). what I disconnected that caused my problem. All works fine before. Does anyone have diagrams to refer to? Is there anyone close by that has one I can look at?
    Thanks in advance for your help
    Walter
    Last edited by waltreid on Sat Aug 17, 2024 12:35 pm; edited 1 time in total (Reason for editing : wanted to ask if any locals were available)
    Number of posts : 12246
    A108 Side Door locking mechanism trouble Empty Re: A108 Side Door locking mechanism trouble
    Post by donivan65 Sat Aug 17, 2024 2:45 pm
    Do you have the rods switched or on the right connector?
    Number of posts : 2632
    Post by savage Sat Aug 17, 2024 2:51 pm
    On an early Chevy van, I would Guess the door got locked with door handle in open position??
    Hope it Helps
    Number of posts : 8769
    Post by dix Mon Aug 19, 2024 1:18 am
    gmytych likes this post
    Number of posts : 1564
    Post by OutofSight Wed Aug 21, 2024 8:17 am
    waltreid
    waltreid
    Number of posts : 5
    Post by waltreid Fri Aug 23, 2024 10:46 pm
    Thanks for your comments. I figured out how the linkages go to gather but do not have the original retainer clips. I'm using something that works for now but it's easily dislodged. Circle clips fit into the rod channel but have no other ways to stay in place if stressed. Any ideas of where to find the clips that are the original style. I am holding it together with some generic Side-Mount External Retain rings but the do pop off. If anyone has a picture of a working side door linkage, that may help me find something that will work.
    Post by dix Sat Aug 24, 2024 5:22 am
    call Steve Scott 330-243-4343
    he is in Ohio with lots of parts.
    did you use a magnet to see if its on the inside bottom of the door ?
    mention vintage vans..
    savage and gmytych like this post
    Post by OutofSight Sat Aug 24, 2024 9:24 am
    I have some spares, let me see if I have what you need.
    waltreid
    waltreid
    Number of posts : 5
    A108 Side Door locking mechanism trouble Empty More information for what I need
    Post by waltreid Thu Aug 29, 2024 10:14 pm
    Thanks Dix for posting the article. I actually stumbled on to it earlier. But it didn't seem to help me so much. I saw the pictures when I found the article but do not find pictures in your post.
    No matter, If I can find a way to post a picture you will see the connection and its two slotted connections without a retainer.
    Here's a picture of the linkage
    A108 Side Door locking mechanism trouble Door_l11
    Yes I did search using a magnet. Nothing found.
    I guess the linkage is okay but the retainers are not existent.
    Ill Call Steve Scott to see what he has.
    Thanks!-Walt
    savage likes this post
    Post by donivan65 Fri Aug 30, 2024 12:44 pm
    Something like this?
    A108 Side Door locking mechanism trouble Img_2063
    A108 Side Door locking mechanism trouble Img_2064
    savage and dix like this post
    waltreid
    waltreid
    Number of posts : 5
    Post by waltreid Sat Oct 05, 2024 11:04 am
    Don,
    Thanks for the diagram. it's not the side door mechanism but I may have the issue solved. I have a couple of retainer clips being sent by Scott. Hopefully they will last at least half as long as the originals.
      Current date/time is Sun Nov 17, 2024 11:25 pm
