I just started restoring my A-100 all window van. It has a uninstalled spare heater box with core and fan motor. My question is where is the factory location for this unit. the undercarriage has no holes marking its exact location.
REAR HEATER
lboast- Number of posts : 112
Registration date : 2020-11-01
REAR HEATER
Re: REAR HEATER
I have never seen a rear heater.
- Number of posts : 8728
Re: REAR HEATER
passenger rear opposite of the fuel filler
Re: REAR HEATER
Just anywhere back there in the opposite corner? it doesn't have any predrilled holes or indicator indents to guide the exact location in the corner?dix wrote:passenger rear opposite of the fuel filler
Re: REAR HEATER
I just received my copy of the Dodge Trucks service manual, and it refers to the rear heater as a model 92, that goes with the model 90 front heater.lboast wrote:I just started restoring my A-100 all window van. It has a uninstalled spare heater box with core and fan motor. My question is where is the factory location for this unit. the undercarriage has no holes marking its exact location.
Re: REAR HEATER
the heater was not a typical install more of a special order
i would not install electric wires or heat next to the gas tank fill tube
the other side depends on the spare tire location where ever you want to run heater hose to.
lboast likes this post
Re: REAR HEATER
I saw an interior picture on the internet that showed the rear heater mounted behind the battery box. could this be considered the correct mounting location for this accessory heater, or was the mounting location optional?
Re: REAR HEATER
you can put it where ever needed, behind passenger seat fits well also just a matter of running heater hose and a switch location,
