    G10 shifter bushing
    PandLChevyVan
    PandLChevyVan
    Number of posts : 45
    Registration date : 2012-01-02
    G10 shifter bushing  Empty G10 shifter bushing
    Post by PandLChevyVan Thu Nov 05, 2020 8:45 pm
    Any suggestions on where I can order the shifter linkage bushings at the bottom of Steering column for 1st Gen Chevy.  Also need the .031 washer shims that go on the transmission shift arms .50 ID .75 OD .031 thick
    G10 shifter bushing  Dscn0049
    gfleduc
    gfleduc
    Number of posts : 349
    G10 shifter bushing  Empty Re: G10 shifter bushing
    Post by gfleduc Fri Nov 06, 2020 4:08 am
    The bushings have a few sources - search the web for Part number ATP JO-119
    Summit & eBay have them.
    Where do the shims go?
    PandLChevyVan
    PandLChevyVan
    Post by PandLChevyVan Fri Nov 06, 2020 7:18 am
    Thanks for the bushing I did find them on SummitRacing site. The shim is at the linkage to transmission arm. It’s just a thin washer basically. G10 shifter bushing  49b10910
    gfleduc
    gfleduc
    Post by gfleduc Fri Nov 06, 2020 9:00 am
    Yes per the parts book a "washer" - Not that it helps much P/N 3772165. Size = 17/32 I.D. x 7/8 O.D. x 1/32 T
    PandLChevyVan likes this post
    PandLChevyVan
    PandLChevyVan
    Post by PandLChevyVan Wed Nov 11, 2020 7:45 pm
    Well Im back looking for the bushings. Everywhere I have looked they are not available on back order from supplier Summit was giving me a date of mid January. Any suggestions??
    Skapbil
    Skapbil
    Number of posts : 19
    Registration date : 2016-01-29
    Post by Skapbil Thu Nov 12, 2020 9:38 am
    PandLChevyVan wrote:Well Im back looking for the bushings. Everywhere I have looked they are not available on back order from supplier Summit was giving me a date of mid January. Any suggestions??
    JO-119 bushings are listed on ebay - prices are high though.
    For the washers - try aircraft supply stores.  The hardware (nuts, bolts, washers) are made to tighter tolerances.
    The washer you are looking for is a AN960-816L
    OD - 0.875
    ID - 0.515
    Thickness - 0.032
    Aircraft Spruce has them - they sell individual pieces and shipping is very reasonable.
    www.aircraftspruce.com
    PandLChevyVan
    PandLChevyVan
    Post by PandLChevyVan Thu Nov 12, 2020 11:11 am
    I was able to have the washers made at a machine shop at no cost my brother took care of me on that.. I did see the bushings on ebay and just refuse to pay that much for a tiny little thing..I spoke with one of the suppliers and they said those bushing were red flagged as unavailable till after the first of the year..
      Current date/time is Wed Sep 27, 2023 2:19 pm
