    Rear spring shackles and bushings 1969 Gen2
    Fcat
    Fcat
    Number of posts : 78
    Registration date : 2019-02-11
    Rear spring shackles and bushings 1969 Gen2 Empty Rear spring shackles and bushings 1969 Gen2
    Post by Fcat Fri Jun 19, 2020 9:36 am
    Hi, I'm looking for an axle set of Rear spring shackles and bushings for a 1969 Gen2 250ci. Ideally someone who will ship to the UK but I can get friends to forward if not.
    I think the rusty, ruined ones I have are original so I'm in for some 'fun' - if I can find some!
    Thanks
    Ian
    Number of posts : 2632
    Rear spring shackles and bushings 1969 Gen2 Empty Re: Rear spring shackles and bushings 1969 Gen2
    Post by savage Fri Jun 19, 2020 1:38 pm
    I'll look. Guessing yours is a G-10???
    Number of posts : 12254
    Post by donivan65 Fri Jun 19, 2020 3:48 pm
    ,,,a possibility,,,,make some or go to an off road shop for a lift kit if thats all you need,,,
    Rear spring shackles and bushings 1969 Gen2 Dscn0926
    Fcat
    Fcat
    Post by Fcat Sat Jun 20, 2020 6:07 am
    Thanks Guys
    Yes Savage it is a G10.
    Good idea re off-roaders Donivan, that may be how it goes, any thoughts on the spring bushings and tips for getting that top bushing out?
    Cheers
    Ian
    Post by donivan65 Sat Jun 20, 2020 2:01 pm
    If,,,,,,you dont have it apart,,,,,,put a jack on top of the spring and jack the body up enough to take the pressure off and take the shackle apart,,,see if you just have these 4 rubber half  bushings in there,,,,we put neoprene ones in there and we have to use a sleeve for that 1/2" bolt,,,see what you got in there,,,,,
    Rear spring shackles and bushings 1969 Gen2 Dscn0928
    Rear spring shackles and bushings 1969 Gen2 Dscn0927
    DanTheVanMan likes this post
    Fcat
    Fcat
    Post by Fcat Sat Jun 20, 2020 3:25 pm
    Thanks Donivan
    Good trick with the jack, It doesn't look like mine has ever been apart and I can see the crumbling rubber of probably the original metallastic bush (that's what we call them). I can imagine that the top bushing (through the chassis) is going to be a mission!
    I'm definitely interested in Neoprene or Poly replacement, the only dimension I have to work with is that the springs are 3" wide - are the bushings standard parts?
    Post by donivan65 Sat Jun 20, 2020 5:38 pm
    You need to see what you got,,,,,,lots of stuff could of gotten changed in 50 years,,,,,springs get changed,,,normally the forward end of the spring has the metal cartridge,,,,,while the rear shackle has 2 half bushings on each bolt,,,,,,once we see what size,,,,,,hole,,,,,,we have in the spring and body,,then we find a bushing that fits,,,,,,and  put a sleeve on the bolt if the hole in the center of the bushing dont match our bolt,,,,I would say you got a 1/2" bolt,,,,,,then you can see if you can find a metal cartridge or rubber bushings for the shackles,,,,,or,,,,convert everything over to neoprene,,,,see if these are what you got,,,,
    Rear spring shackles and bushings 1969 Gen2 2nd_ge14
    Fcat
    Fcat
    Post by Fcat Sun Jun 21, 2020 4:13 am
    OK, I'll have a look. Hopefully I'll have the half bushings in the shackles to make life easier. Then Neoprene back in with sleeves.
    Fcat
    Fcat
    Post by Fcat Sun Jun 21, 2020 6:30 am
    OK, Unfortunately I don't have a chassis rail to jack against but I had a good look at the setup and checked that everything will undo.
    So it would appear that I must have half bushings in the top of the shackle as there is not enough room to withdraw the shackle bolt between two chassis rails - the half bushings would allow wriggle room to withdraw the bolt at an angle.
    https://i.servimg.com/u/f60/20/05/18/39/tightf10.jpg
    The bushings in the spring both appear to be metalastic.
    gfleduc
    gfleduc
    Number of posts : 377
    Post by gfleduc Mon Jun 22, 2020 6:09 am
    Fcat
    Fcat
    Post by Fcat Mon Jun 22, 2020 6:19 am
    Thanks Gary, are these the same as the rears for my G10?
    gfleduc
    gfleduc
    Post by gfleduc Tue Jun 23, 2020 4:59 am
    I cannot say for sure, as I never bought - I would expect them to as the part number crossed over to GM P/N 6272088 for 2nd Gen van front or rear.
    Fcat
    Fcat
    Post by Fcat Tue Jun 23, 2020 6:59 am
    Good starting point anyway - thanks Gary
    Fcat
    Fcat
    Post by Fcat Sun Jul 12, 2020 7:21 am
    Just an update on this - so far I have dropped the rear of the spring and removed the shackle bushings. They are the same top and bottom and there were no sleeves (I'm sure this made the job 10x easier).
    The sizes look odd to me as I am usually working in metric and I haven't found any similar yet - do they look familiar to anyone?
    Thanks as ever guys
    Rear spring shackles and bushings 1969 Gen2 Shackl11
    gfleduc
    gfleduc
    Post by gfleduc Sun Jul 12, 2020 7:40 am
    Resize you photos & they will fit; some thing like 600 x 600
    HB-930  bushings:
    Ø 1-1/8"
    OAL 1-15/16"
    Barrel 1-7/16"
    Ø 9/16" through hole
    Fcat
    Fcat
    Post by Fcat Sun Jul 12, 2020 8:00 am
    Thanks Gary
    Fcat
    Fcat
    Post by Fcat Mon Jul 20, 2020 7:19 am
    If only these thing came apart as easily as they go back together - 10 mins to replace the shackle bushings (HB-930) that arrived today!
    Does anyone have a part number for the front bushing on the 2nd Gen rear spring?
    gfleduc
    gfleduc
    Post by gfleduc Mon Jul 20, 2020 8:15 am
    Here is the parts book number:
    7.413 BUSHING, Front Spring Eye
    67-70 G-10-20 ........................ .................................... 3890384
    https://www.truckspring.com/products/Rubber-Leaf-Spring-Bushing-Type-1__RB-99.aspx
    Lots of hits on the RB-99 P/N
    Fcat
    Fcat
    Post by Fcat Mon Jul 20, 2020 8:49 am
    Thanks Gary
    Fcat
    Fcat
    Post by Fcat Tue Sep 29, 2020 10:32 am
    After a struggle with rusted bolts I managed to drop a rear spring and the bushings I have for the front eye are way too small. My springs are the ones with 3" eyes that taper for the U bolts.
    The dimensions I have are:
    1 1/2" diameter
    3" external length
    3 1/2" overall length
    1/2" internal
    Closest I have found is: RB-98 Rubber Bushing 1.5 O.D. 9/16 I.D. 3 Length 3.5 Overall Length https://www.stengelbros.net/RB-98-Rubber-Bushing-15-OD-%C2%A0-916-ID-3-Length-35-Overall-Length_p_6879.html
    Just the internal bolt hole being too large.
    Is anyone familiar with this bushing?
    Thanks guys
      Current date/time is Tue Jan 14, 2025 5:53 am
