    Antenna Mount
    hemicop
    hemicop
    Number of posts : 89
    Registration date : 2011-12-18
    Antenna Mount Empty Antenna Mount
    Post by hemicop Fri Sep 13, 2019 7:14 pm
    Well, since no one's bought my '64 A100 yet, I'm still playing with it. Which leads me to my question------- does anyone have (or knows where I can get) the relatively thick base gasket that goes under the tear-drop shaped antenna base?
    The antenna has a large mounting base the cable goes into with a fixed nut attached to it. I suppose I could simply drill a larger hole to have the nut pass through it but apparently the factory didn't do THAT for some reason.
      Current date/time is Mon Oct 02, 2023 10:51 am
