Hey All I'm a little concerned about the amount of threads holding. on my rear aluminum wheels. At best I think there is about 3/8 of an inch of thread to stud Can longer wheel studs be bought and has anyone have to same problem
rear wheel studs
dougtappan- Number of posts : 310
rear wheel studs
Kakster- Number of posts : 236
Re: rear wheel studs
Yikes ....those studs are 3 inches long do I need that length or are those for duel wheels
- Number of posts : 2087
Some mags can use what are called e.t.(extended thread) nuts.
you can get wheel studs in whatever length you need.
You need to get the axles out, but then you can change em out yourself with a big hammer, or if you have a press, even better
m1dadio- Chevy Guru
- Number of posts : 1778
your wheel nuts need 9 threads of engagement and 90 to 100 Ft/Lbs torque.
The standard studs are usually a little short you can knock them out with a hammer without removing the axle and pull the new ones in with an inverted wheel nut, a couple large washers and an impact gun.
You have a G10 van right?
Use NAPA wheel stud 641-1267 they are the same splined fit in the axle and about 3/8" longer
https://www.napaonline.com/en/p/NDP6411267?keywordInput=noe6411267
M1D
M1D
Many thanks M1D
