I can't be the only person with this issue:
The set of front doors that came on my 69 van had the area around the bottom hinge bolts almost completely cracked away.....I bought a second set of doors and they were the same way.....
Upon further examination, I noticed that, although nothing is making contact, there seems to be a spot in the arc where the hinges don't want to come around any farther, so the door does the rest of it's inward travel by flexing the part of the door that the hinges bolt to. You can see it as movement of the hinges, front-to-rear, where they go into the openings in the door....
I've had the hinges off for inspection and it appears that they are capable of going that extra distance.....
One thing I am going to do is make a top-to-bottom 3/16" plate to stiffen the front of the door, but it isn't going to help much if I cant solve this geometry issue...
The set of hinges on the van are nice and tight (don't need re-bushed), so I'm not anxious to use any heat to re-shape them that might melt the bushings....
