spindles from 11" brakes. I believe 2500# axle.
older style heater control. 3 cables all work and wires from switch to blower
battery box is quite repairable. just the acid burn through seen in pic.
got a couple horn centers very good shape considering some I've seen. a couple signal lite switches.
got a box with a bunch of gauges and a speedo head.
I have some other stuff too. 1 complete steering column, box and shifter linkage, signal lamp switch. wiper motor and all the linkage. gas tank straps (2) for dual strap tank. front signal lamp assembly's with amber lenses. couple rear buckets and lenses. a painted grille. several used and slightly dented headlamp rings. plastic door panel inserts are just fair but in a bind could be repaired.
