    some of the inventory
    Number of posts : 1148
    some of the inventory Empty some of the inventory
    Post by jkr Mon Nov 19, 2018 4:09 pm
    some of the inventory A-100_14
    spindles from 11" brakes. I believe 2500# axle.
    some of the inventory A-100_15
    older style heater control. 3 cables all work and wires from switch to blower
    some of the inventory A-100_16
    battery box is quite repairable. just the acid burn through seen in pic.
    some of the inventory A-100_17
    got a couple horn centers very good shape considering some I've seen. a couple signal lite switches.
    some of the inventory A-100_18
    got a box with a bunch of gauges and a speedo head.
    I have some other stuff too. 1 complete steering column, box and shifter linkage, signal lamp switch. wiper motor and all the linkage. gas tank straps (2) for dual strap tank. front signal lamp assembly's with amber lenses. couple rear buckets and lenses. a painted grille. several used and slightly dented headlamp rings. plastic door panel inserts are just fair but in a bind could be repaired.
      Current date/time is Mon Nov 25, 2024 7:13 am
