    67 Dodge A-100 van Camper Pop Top V8 318 (CA) Ebay
    a100_Bubba
    a100_Bubba
    Number of posts : 2650
    Registration date : 2012-03-08
    67 Dodge A-100 van Camper Pop Top V8 318 (CA) Ebay Empty 67 Dodge A-100 van Camper Pop Top V8 318 (CA) Ebay
    Post by a100_Bubba Sun Nov 18, 2018 1:48 pm
    https://www.ebay.com/itm/153265787519
    67 Dodge A-100 van Camper Pop Top V8 318 (CA) Ebay S-l1600
    1967 Dodge A-100 Van with pop up camper top. This is not the typical Dodge fabric pop up top or the other half round aluminum top. This top is from an aftermarket company called Freeway Traveler. I found some literature online and it was a company from Elkhart, IN. You could choose your options for the top and then you would pick a local distributor in your area for the install. I would think this conversion was most likely done after the van was purchased.The top pushes up with handles from the inside. The top is still in good working condition, opens and closes easily. The sliding windows work. I've washed the van and did not have any leaks inside. This has the electrical and water ports on the driver side. I would think that this would have had a stove, sink and refrigerator at one time. Entire rear floor area is solid and rust free. I do not know when the van was painted. It's not perfect but it cleaned up well with some compound and wax.
    This van is ready to drive and enjoy. Compared to most of the vans that need heavy rust repair and mechanical work, you'll be ready for cruises and shows for next season.
    Videos of the van running can be seen on YouTube by searching 1967 Dodge A100 van test, drive test drive 2, idling on driveway, radio working. They were all taken today 11/17/18.
    Clean California title in my name, currently registered, current tags and plates
    318 engine (1970 block) 727 automatic transmission, 8 3/4 rear with 741 case
    Edelbrock 1405 600 cfm 4bbl carb sits on a later model cast iron 318 intake (4095080). Vintage Holley valve covers
    Tires: 225/70/15 Tires are Big-O brand with very good tread, almost like new.
    Van has good power, shifts well, steering is tight. All doors close properly.
    Dual Flowmaster mufflers turn down just before the rear end
    Seats are from another car, I don't know the model. They are bolted down but are still a little loose. They need to be bolted on one of the rear mounts. The seat belts are there.
    Working:
    Head lights, tail lights, turn signals, radio, wipers, horn (sometimes), heater/blower
    Missing: Cover for master cylinder, battery box top, key for doors.
    Cons/needs work:
    Drum brakes work but system may need to be bled and gone thru again to make perfect.
    Speedometer bounces but odometer works.
    11/17/18- I filled it with 16.4 gallons of gas ($69.00) until it stopped. Fuel gauge registers 3/4 full.
    I had a small oil spot on the driveway and I think it may be coming from the oil dipstick tube. It does not seal well in the block.
    Rust issues/dents:
    Van is very solid overall. The spot on the windshield A pillar is the worst of it all but it does not go all the way thru to the inside. I stripped this down with a disc so you can see it. The entire front floor is solid with the exception of the edges of the driver and passenger foot area. -- The step area on the driver side has some small holes.
    - One small hole on top of the rear wheel tub.
    - Rear corner bumper area is dented as you can see, along with the rear are where the bumper would have been mounted.
    - The roof rails are perfect, no rot. Entire rear floor area is solid and rust free.
    - small rust bubble on driver and passenger door
    $500 deposit due at auction end. Non-refundable. Buyer is responsible for all shipping costs, phone calls. Please contact me ASAP if you have any questions regarding shipping.
      Current date/time is Mon Nov 25, 2024 8:38 pm
