    Neutral Safety Switch
    63chevyvan?
    Number of posts : 125
    Neutral Safety Switch Empty Neutral Safety Switch
    Post by 63chevyvan? Mon Oct 08, 2018 5:07 pm
    Hi all! The engine harness interconnect plug on the 64 has seen better days; it is broken and corroded. I am trying to figure out the wiring using a 65 wiring diagram. It shows (2) purple wires for a safety switch, but my harness has only (1) purple wire. Did 64's not have a neutral safety switch ?
    Gears & Cheers, MS
    Number of posts : 801
    Neutral Safety Switch Empty Re: Neutral Safety Switch
    Post by panelmanrd Wed Oct 10, 2018 6:25 am
    if your van was an automatic it might have the switch but not
    100% positive about a 64. if it was a manual trans van it won`t
    have the switch factory.
    Number of posts : 1651
    Post by Scott Wed Oct 10, 2018 11:22 am
    I saved the wire diagrams for different year vans, can't remember where I pulled them from, but the oldest I have is for a 65. Looking at this one I see the NSS on it, I highlighted it yellow.
    But, like panelmanrd said, I don't know if this applies to a manual transmission.
    Neutral Safety Switch 65_wir10
    63chevyvan?
    Post by 63chevyvan? Wed Oct 10, 2018 8:20 pm
    I have your 65 wiring diagram, Scott; thanks. I thought 1st Gens only came with manual trans, but a 66 diagram I have, refs a RPO M35 (PowerGlide ?). Anyway, my Van came with a manual trans, but at some point in time was converted to V8/TH350 auto and I have not found a NSS.
    I ended up cutting open the engine harness to try to figure out what I have. It looks like a cobbled 67 harness; no resistance wire (had HEI), extra (2) wire connector (green/dkgreen), brown wire not used (single wire ALT with internal reg), no pruple/white wire, and black wire misconnected.
    So, I did the following:
    1) connected black correctly
    2) deleted brown wire
    3) deleted extra (2) wire connector green/dkgreen
    4) added purple/white wire and ballast resistor for Mallory/Pertonix distributor
    Thanks to panelmanrd and Scott
    Gears & Cheers, MS
    Number of posts : 1389
    Post by wideload Thu Oct 11, 2018 4:04 am
    Don't know if this will help at this point, but there are colored wiring diagrams in the Archived section of the forum. Make sure to scroll to the bottom of the First Gen Diagram post, there have been some changes made since the original post.
    Post by panelmanrd Thu Oct 11, 2018 6:26 am
    the 64 chevy i have at home in the works was an auto
    had a powerglide, just dont remember if there was a
    nss switch.
    most aftermarket shifters have the nss built in.
    i have a late 60 chevy horseshoe shifter in my van
    and it has an nss in it.
    63chevyvan?
    Post by 63chevyvan? Thu Oct 11, 2018 10:22 am
    OK, the harness now looks like the 65 diagram except no brown wire and no NSS. I forgot to mention earlier that I found a yellow wire in place of a purple/white wire (now correct purple/white).
    The 3 speed column shifter is used for the TH350. I am going to install a stop screw to eliminate the pull up motion on the manual shift lever.
    Thanks all, MS
    Number of posts : 1048
    Post by VANagain Sun Oct 21, 2018 1:06 am
    The nice, color wiring diagrams are here:
    https://vintage-vans.forumotion.com/t25630-first-gen-wiring-diagram?highlight=Wiring+diagram
    The diagrams confusingly show two purple wires but you will only have one, either with an NSS connector or without. Most early vans won’t have it. My 65 Sportvan Deluxe came with a powerglide but no NSS connector. Scotty’s 65 Deluxe had the purple wire going to a NSS connector but it was just hanging there. No actual NSS switch on the tranny.
    Since you’ve got the TH350, you’ll want to find a NSS made for that. Then you cut your purple wire and splice in a connector to go to the NSS. That wire goes to the “S” terminal on the starter solenoid. It gets energized when you turn the key to Start. The NSS connects the cut wire only if it’s in Park or Neutral.
    Since the TH350 is a newer transmission, its NSS will also has wires to light your backup lights when in Reverse. Might as well hook those up too, if your van has backup lights.
      Current date/time is Mon Nov 25, 2024 6:13 pm
