A friend has a 68-70 ? A100 panel van V8. (unsure of year/ but it does have the wing crash pad).
It has a 3 speed manual trans. The speedo cable goes into the passenger side of the trans. Unsure of the trans model/ID
I crawled under to look at the speedo connection (at the trans). I could not see the aluminium adapter for the speedo pinion adjustment part. Like it does not have the aluminium adapter.
He changed rear end ratios a while back. And now his speedo is off. If he's going actual 42MPH/ the gauge shows 38MPH. So the speedo gear needs to be spinning faster/less teeth.
Does anyone know what 3speed manual he may have? and does anyone know if you can install different speedo pinions / need information Please Thank you .
