Can anyone take some pictures of their short tailshaft 3 speed manual transmission of their A100's. The pictures I'm most interested in would be of were the speedo cable inters the transmission. and to see if there is the aluminum speedo adapter (like the automatics used)
A100 manual trans pictures needed
Dan Scully- Number of posts : 254
Speedo
Last edited by Dan Scully on Sun Aug 05, 2018 9:58 pm; edited 1 time in total (Reason for editing : txt)
The link you provided did not come through. (at least on my end) Could you pleas try again ? Thanks
Speedo
I did not post a link just 2 pics from the parts manual. I can see them in my post. Do not know why you can not see the pics?
Scott- Number of posts : 1651
I can see the pics
I can see them now. Thanks that helps a lot. Does the parts book list different speedo pinions for different tire sizes/gear ratios ? if so could you list that information. Thanks
Speedo
Thanks
Speedo
If you need the teeth# give the pt# and I ,ll look it up in the parts book.
Re: A100 manual trans pictures needed
That would be great. Also I could not read the tire size information (not very clear). I want to thank you for all your help
Speedo
Save the pic than open it up and enlarge it and you can see the tire sizes better.
I save it, an enlarged it and used magnifying glass...still to hard to read (all I can see good is the rim size) And could use tooth count when you get the time. Thanks
Speedo
Thank You So Muchhh !!! You are the Man
One last question....and I will stop being a PITA
You said you may be able to get the pinion tooth count. The pinion I need is part number 2204355. I could use the tooth count if possible/ if not you've help me so much. Thank You
rustytoolss wrote:Thank You So Muchhh !!! You are the Man
I ,ll take a look later today and get that for you.
They do not show the tooth count. All it shows is tire size pinion ratio and the pt # you need for the drive gear and speedo pinion for that combo. I guess you would have to physically count the teeth on that part# ?
