    Does a 68 A100 3 speed use an A-745 Trans?
    Number of posts : 957
    Does a 68 A100 3 speed use an A-745 Trans? Empty Does a 68 A100 3 speed use an A-745 Trans?
    Post by slowflapper Fri Mar 08, 2013 2:47 pm
    My '65 has an A745 manual, I found one locally for $125 I'm going to get as a spare and just want some assurance its the same trans.
    I think all the A100 manuals use the A745.
    Does a 68 A100 3 speed use an A-745 Trans? Empty Re: Does a 68 A100 3 speed use an A-745 Trans?
    Post by slowflapper Fri Mar 08, 2013 3:09 pm
    IIRC the ID plate on the van shows the trans type, Ill check it when I pick up the trans
    Post by slowflapper Sat Mar 09, 2013 1:20 pm
    Ok, need some expert info.
    I went and checked out the trans and it is an A745 like I need however, it appears that "something" has broken off the housing around the input shaft. You can see the break in the picture below, I don't know if this is purely a cosmetic issue or not having never seen one of these out the vehicle before. It looks like whatever it was broke off long ago judging by the grease that's on it, does it matter that its broken?
    If its a needed part, can this part be replaced?
    Anyone seen one of these before?
    Does a 68 A100 3 speed use an A-745 Trans? Trans
    Post by slowflapper Sat Mar 09, 2013 1:41 pm
    slight update, after some googling it looks like that piece should extend out to the gear splines (protecting the shaft) so it is a needed part. Looks like it extends through the clutch pack as well.
    Here's an image of a long tail shaft A745 but you can see where the thing extends out.
    Does a 68 A100 3 speed use an A-745 Trans? A20791d13756d4908d6ce4_m
    it also looks like a rebuild kit for one of these is only about $125, it might be worth it just to rebuild mine later and forget about the spare.
    Number of posts : 2036
    Post by dodge man Sat Mar 09, 2013 2:47 pm
    its what your throw out bearing rides on, when you install it wape a very small amount of grease around it
    Post by slowflapper Sat Mar 09, 2013 4:45 pm
    dodge man wrote:its what your throw out bearing rides on, when you install it wape a very small amount of grease around it
    So in this case that trans isn't worth anything but spare parts without a new part to replace the broken one. I'll make the guy an appropriate offer for it, and some other small pieces, and see what he says.
      Current date/time is Wed Oct 09, 2024 8:59 pm
