Hi everybody. Let me explain what I have. 1961 Econo van 3 speed manual with a 9" rear with I believe a 304 to 1 ratio. Just installed a fairly fresh rebuilt 200 from a 67 mustang, bored 30 or 40 over. Electric Fan, 130 amp alt. Wanted to replace the old hardened motor mounts with new ones. As far as I know the 144 mounts should also fit the 200. Ordered new mounts from Macs, brand name Auto Extra. Noticed that the mounting holes for block sat 3/8" higher than the originals. Not knowing but thinking this might create a problem with tranny clearance I ordered another set from Advance Auto, brand name Anchor. They were exactly the same, right down to the number stamped on it as the ones from Macs. I may have mixed them up but that shouldn't matter so I grabbed 2 of them and installed them. About half hour later, still on the lift working on other things I noticed the engine looked crooked. Here the passenger side mount failed, the metal separated from the rubber and sank down. What the heck!!!!! So I grabbed another one and replaced it. Seemed to be ok. Returned the bad one and the other one that I thought was the pair to that one back to Advance. Finished up some wireing for the fan and alt. Had gone on vacation for 2 weeks to CO. While the van remained on the lift until I returned. Finished the dog box lid insulation by 1:00 am sat. Mourning. got some sleep and drove it to work for the maiden voyage test run. Came home only to find the passenger side failed again. Now I'm getting a little frustrated. Called Macs and asked for my money back. Ordered another set from Auto Zone, manufacturer was Delco. These also looked exactly the same as the other sets with the same number stamped on. Installed them on Thursday night. Drove to work Friday, came home, went to a cruise in at a diner. Woke up this mourning, did a slight timing adjustment, went for a test drive, parked it to check the timing again after feeling a slight vibration only to find both mounts failed. What the heck is going on here. Am I missing something here or are all of these motor mounts JUNK from China or something. None of them lasted even 50 miles. The inner metal part that bolts to the block keep separating from the rubber that it's supposed to be bonded to. Does anyone know were I can find a good reliable set of motor mounts or an alternative? PLEASE HELP!!! ( Bryan) Oh by the way, also replaced gas tank with a 69 mustang 20 gallon tank which I had altered to fit and rebuilt the heater controll valve with a rebuild kit from Napa which consisted of an $8.00 rubber part for the valve. Both are working fine.
Last edited by Vangoat on Sat Jul 14, 2018 2:51 pm; edited 1 time in total (Reason for editing : Just forgot to add to list of things l had done to it.)
