by Old Skool Sat Jun 13, 2009 7:04 pm
Hey guys,, new to the site, perhaps a few know me from old econolines, vic, Have enjoyed reading here and there, few members have asked if I might like to join in and help if I can, so hope no one minds jumping in on this one.
From the pictures, that is for sure an AFTERMARKET adapter setup to use a different M/C. Looks familiar, but will look up what I have later on, Maverick or Mustang I think? anyways,, noticeing couple of things first off. The pics dont show all of it,, but looks like at least part of the 67 two pc white plastic brake light switch cover, the 67 offset return spring bracket, and suspect the 67 brake switch,, also pictured just under that, antoher pressure type switch, which, would be my guess as to the early brake light switch setup, however, only hooked up to one circuit????? need more to talk about that??? as why use the two circuit 67 brake light switch, and then dissable it and use only one side????
Our original 67 "distribution" block, was not actually a proportioning valve, and only had an idiot light switch to tell you a circuit was not operating. Also, if you try to use a "preset" proporioning valve, you are still guessing as to the brake bias of that vehicle it was intended for. Meaning it may or may not work for your econoline brake bias. whew,,, sorry, The reason I use an adjustable proportioning valve and fine tune it to the vehicle.
If the bore is pitted, it can leak pressure backwards and or not hold the pressure, but that M/C looks pretty new?? I would suspect firstly air in the pistons or lines, rear wheel cylinders, or also a leak in any of those, to include the brake lines.
There are quite a few conversions out there, I make and sell one also. Part of designing the setup is the original rotor and piston travel, versus the conversion rotor thickness and travel?? and proper pad placement on the rotor, sometimes hanging over is okay, but consider that is less stopping area applied, and wears things funny. Personally, was very careful in designing that out of mine. That should not be making the problem you are having. Suggest cleaning everything spotless with brake cleaning solvent, drive it IF YOU CAN SAFELY, or pump the heck out of it, even if only in reverse and forward in the driveway, and inspect everything carefully again, if its leaking, and you cleaned it good it will show. Also it is said, especially on the 67 brass seats are over tightened, it can leak only on the return stroke, and not on the pressure stroke, sucking in air also.
vic/ca
