solospeedshop
    1966 Turn Signal Switch
    solospeedshop
    solospeedshop
    Number of posts : 62
    Registration date : 2014-05-06
    1966 Turn Signal Switch Empty 1966 Turn Signal Switch
    Post by solospeedshop Tue Dec 05, 2017 7:21 pm
    Hey guys!
    66 chevy van Turn signal switch is it the same as Truck? Availabilty? Part Number? Tks Bill
    Number of posts : 890
    1966 Turn Signal Switch Empty Re: 1966 Turn Signal Switch
    Post by jrinaman Tue Dec 05, 2017 8:14 pm
    Number of posts : 12246
    Post by donivan65 Tue Dec 05, 2017 8:23 pm
    Ebay or truckandcarshop.com
    1966 Turn Signal Switch Dscn0214
    1966 Turn Signal Switch Ts10
    67VanHelsing
    67VanHelsing
    Number of posts : 118
    Post by 67VanHelsing Wed Dec 06, 2017 9:20 am
    Thanks for sharing!
    solospeedshop
    solospeedshop
    Post by solospeedshop Wed Dec 06, 2017 2:09 pm
    Thanks Guys! Bill
    Number of posts : 1412
    Post by Vantasia Fri Dec 08, 2017 12:49 pm
    Did you get one? Remember, the trick to installing one is to remove the wires from the curved plugs using a small screwdriver to release the tab on the wire sockets. That's the only way to feed the wires through the hole in the collar on under the steering wheel, this is even described in the original shop manual! The switch instructions don't tell you this. Be sure to write down the order of the wires so you put them back in the plugs correctly! If you already knew this, its a public service message for any newbies who might not know and might cut the plugs off and try to splice the wires back! They slip right out if you do it right!
    solospeedshop
    solospeedshop
    1966 Turn Signal Switch Empty Public Service Message!
    Post by solospeedshop Fri Dec 08, 2017 1:38 pm
    Thank You! that was very nice! Switch not here yet but its coming! Bill
    Rick's 66 Chevy Van
    Rick's 66 Chevy Van
    Number of posts : 331
    Post by Rick's 66 Chevy Van Fri Dec 08, 2017 11:31 pm
    hey solo do you have any seatbelts that will fix my 65 chevy van?
    solospeedshop
    solospeedshop
    Post by solospeedshop Sat Dec 09, 2017 8:21 am
    Hey Rick!
    I have 74" 2 Point Push button lap Belts Vans might need longer measure & see if would work Tks Bill
    Rick's 66 Chevy Van
    Rick's 66 Chevy Van
    Post by Rick's 66 Chevy Van Sat Dec 09, 2017 1:48 pm
    thanks man where did you get yours?
      Current date/time is Sun Nov 17, 2024 11:30 pm
