    squeaking shifter or linkages
    steelrat
    steelrat
    Number of posts : 116
    Registration date : 2014-11-24
    squeaking shifter or linkages Empty squeaking shifter or linkages
    Post by steelrat Wed Nov 22, 2017 4:17 pm
    My 3 in the tree shifter or linkage is making loud squeaking noises when shifting 2nd to 3ed, and 3rd to 1st. How do I lubricate this set up. Thanks Smile
    Canada17
    Canada17
    Number of posts : 49
    Registration date : 2016-03-21
    squeaking shifter or linkages Empty Re: squeaking shifter or linkages
    Post by Canada17 Wed Nov 22, 2017 5:44 pm
    There is a zerk fitting on the shift tube housing. Its accessible through the grill. Start there and then work your way back, you may be grinding on the radiator bulkhead which will require some new bushings to make go away.
    steelrat
    steelrat
    Post by steelrat Wed Nov 22, 2017 6:02 pm
    Thanks so much! I thought I would ask before climbing under and looking about. Great helpful info.
    Number of posts : 2086
    Post by Seth G Wed Nov 22, 2017 7:28 pm
    It can also be rubbing where it goes through the frame bracket in the doghouse area.
    Old Skool
    Number of posts : 1306
    Post by Old Skool Thu Nov 23, 2017 7:24 am
    Its been a very old issue with the worn out bushings in the frame as Seth mentioned. I have electrical replacement bushings that will snap in as a replacement. That should fix the sqeeeeeeeeeeeksz.
     I also rebuild the columns if you have the usual shifting problems.
    OLDSKOOLsqueaking shifter or linkages 100_1310
    Post by donivan65 Thu Nov 23, 2017 11:20 am
    We use this plastic wire wrap to quiet down our Chevy shift rod squeeks,,,,,,,,
    squeaking shifter or linkages Shift_10
      Current date/time is Sun May 19, 2024 10:17 am
