So Fairbanks is junkyard hell. Basically one yard in town with acres and acres of not much!
In my search for E parts:
steelies: $45/each
alloy: $65/each
Kia Rio seats (should work): $75/side
Subaru XT6 seats (still want to try): $100/side
There is a single '68-'74 with pristine shift column and heavier top cap. They won't let me have the small part; all or nuttin' Left with nuttin' for my rig.
I drilled out the rivets and pulled my shift column top cap pieces out. I have pried a little and banged on it some but unable to get splined rivet? to back out in order to separate the little top cap. If I can't find a heavy cap, I will weld something heavy. Has anyone come up with a way to pull that rivet out? Could just weld over the top but I'm sure someone has done this.
steelies: $45/each
alloy: $65/each
