    Acura Integra Disc Brake Conversion?????
    FancyFlush
    FancyFlush
    Number of posts : 62
    Registration date : 2014-05-21
    Acura Integra Disc Brake Conversion????? Empty Acura Integra Disc Brake Conversion?????
    Post by FancyFlush Tue Jul 19, 2016 8:28 am
    Found this on a post at "oddballcustoms"  regarding a disc brake conversion...
    I found that 97 Integra type R had the same Ford bolt pattern, So I knocked the drums off the spindles and mounted the rotors to the spindles, once I had the Calipers mounted where I wanted them, the was a 3/8 difference -perfect, that allowed me to make a 3/8 plate with both bolt patterns -one for the spindle and one for the caliper carrier. The steering stops will need to be adjusted as the caliper will hit the bolt that attaches the sway bar to the beam, if you mount them behind the caliper will hit the shock. I used the Integra flex line and changed the steel line to a metric fitting. Then Obviously change the master and put the biggest booster you can in there…. Usually a 7″double Diaphragm
    Acura Integra Disc Brake Conversion????? Empty Re: Acura Integra Disc Brake Conversion?????
    Post by vanny Tue Jul 19, 2016 8:57 am
    I can't see the pic below your text. It's always nice to have other options available ...Thank you for posting. So, did he do this on an Econoline or some other Ford?
    jdlaugh
    jdlaugh
    Number of posts : 298
    Post by jdlaugh Tue Jul 19, 2016 9:59 am
    Found it via the wonders of Google. It's on an Early Econoline:
    Early Econoline Disc Brake Conversion
    Acura Integra Disc Brake Conversion????? Econoline-disc-adaptor
    Acura Integra Disc Brake Conversion????? Img_4081-medium
      Current date/time is Thu May 02, 2024 2:55 am
