    Sound proofing the dog house?
    Sound proofing the dog house? Empty Sound proofing the dog house?
    Post by Guest Thu May 07, 2009 5:22 pm
    One of the many things I want to do to my 66 G10 is sound reduction. As far as the dog house goes, this is what I was going to explore.
    In my sound proofing experience, (done a few quiet rooms and recording studios), the key to sound reduction is having two non continuous solid surfaces, (you may have heard a 'room within a room'). The density and thickness of those surfaces counts to an extent, but what I found is you get like 80% there just by having two walls that don't touch.
    So considering that, I figure fabricating an inner dog house out of some relatively thick gauge sheet metal, (providing there's enough clearance for it), that attaches to the outer one at the base could potentially do a lot towards insulating you from the growl of your 6 or 8 pounding under your elbow. The weak link becomes the floor, but there are things one can do for that as well. Cross that bridge later.
    Anyone ever explored the sound proofing and sound reduction in their vans? I'd be interested in any tricks you've discovered.
    Cheers,
    Heavy
    Number of posts : 2067
    Sound proofing the dog house? Empty Re: Sound proofing the dog house?
    Post by sasktrini Thu May 07, 2009 5:26 pm
    I'd say new hardware... no 50 year old nuts and bolts. New rubber seals... you'll tighten it up a lot, maybe not have to fabricate stuff! Hi-heat foil insulation / sound deadener... that ought to bring it down a few decibels!
    If you make it too quiet, how are you going to warn the stupid drivers on the 401 that you're coming!?!
    Post by Guest Thu May 07, 2009 5:48 pm
    Hehe, if I scrape enough money and time together to put the engine and exhaust in this van, they'll hear it.
    Number of posts : 7905
    Post by DanTheVanMan Thu May 07, 2009 6:26 pm
    Yes Sir,
    "Load pipes save lives" cheers
    Sound proofing the dog house? Qr_cod10
    Post by G-Man Thu May 07, 2009 8:14 pm
    Sure your idea will work, just never heard of anyone doing it that way.
      Current date/time is Thu Nov 21, 2024 6:33 pm
