    cracked frame on Both sides
    mcVann
    mcVann
    Number of posts : 39
    Registration date : 2013-09-24
    cracked frame on Both sides Empty cracked frame on Both sides
    Post by mcVann Fri Apr 08, 2016 4:01 pm
    AUGH.... I put in air shocks and it drove great, but heard a clunk and looked.... right rear shock broke and the frame is cracked, buckled on both sides where the shocks mount......left and right side frame.
    Do I cut the frame and weld in new box rails?
    Number of posts : 2087
    cracked frame on Both sides Empty Re: cracked frame on Both sides
    Post by Seth G Wed Apr 13, 2016 12:08 am
    Wow, that's crazy. Sorry for your troubles. Sounds like a good plan. The springs must have not been carrying much if any of the load.
    Post by Guest Wed Apr 13, 2016 2:36 am
    I would also inspect the entire frame for further rust damage before replacing the rear rails. Whacking it with a hammer will jar loose flaking rust and hopefully expose any more problem areas. Poke suspect areas with a large screwdriver or chisel, probing for holes.
    Best of luck.
    Post by Guest Wed Apr 13, 2016 6:56 am
    Oops! Just realized you're in California, probably don't have rust issues. That was a Michigan answer to a West Coast problem. Sorry...
    Post by Twinpilot001 Wed Apr 13, 2016 7:18 am
    I would only =stop drill the crack area--- weld  it & grind-- then weld /  gussett (plate) over that area for strength.
    mcVann
    mcVann
    Post by mcVann Sat Jun 09, 2018 8:49 am
    Thank you everyone. and will do Twinpilot001.
    jdlaugh
    jdlaugh
    Number of posts : 298
    Post by jdlaugh Sat Jun 09, 2018 2:33 pm
    Need to figure out why it broke. I agree the springs weren't carrying the load and instead the load was transmitted thru the shocks causing unusual stress on the frame. Need to fix that first then repair the damage as mentioned.
      Current date/time is Sun Nov 17, 2024 7:31 pm
