I installed my new brackets, calipers and rotors from D&D, went for a drive and noticed some wobbling on the right front wheel.
I thought bad bearings and replaced those as well but also noticed that my right hub as a slight crack between two bolts.
When I tightened the wheel back on, the rotor started to scratch on the guide bolts. Had to have a helper holding the rotor centered
while tightening. So now it's not scratching anymore but still wobbling a little.
Could this be caused by the cracked hub?
How can I find out what hubs I have and where to get another one?
Thanks
Thanks
