i worked two years for a machine shop - engine parts store and you could buy 2 sets of 350 chev rings for the price of one set of dodge rings. used rings are throw aways no matter the mileage due to heat cycles. and if you do get a new set to install there is a top and bottom to each and the 2 compression rings are different. check the package instructions carefully. most guys never follow instructions or directions...
