    1966 A 100 mechanic San Diego, etc.
    1966 A 100 mechanic San Diego, etc. Empty 1966 A 100 mechanic San Diego, etc.
    Post by Guest Thu Jan 14, 2016 11:20 am
    I have a 66, A 100 that seems to need some major engine work. It is smoking white smoke after the van starts running for a few minutes. But even when driving, drives good, electrical works, new brake master cylinder, etc.. the only real problem is the smoke. Really embarrassing.
    There are many mechanics in town and around, but non show interest in working on the Dodge. This because its a dodge and there are no parts, easily accesible to replace the ones that could be needing replaced.
    Any suggestions besides attempting to find and buy the similar van with similar motor and hoping the van I purchase (probably from out of state) doesn't have the same problems.
    Suggestions?? Replace with (different size, etc.. ) motor?
    Thanks for your help or thoughts on this matter.
    Number of posts : 8769
    1966 A 100 mechanic San Diego, etc. Empty Re: 1966 A 100 mechanic San Diego, etc.
    Post by dix Thu Jan 14, 2016 2:19 pm
    any and all the engine parts are avail. you need to find a older shop that knows how to work on them
    Number of posts : 12246
    Post by donivan65 Thu Jan 14, 2016 4:21 pm
    go up to profile and put down a better location,,,,,are you in Los Angeles?
    is the smoke from oil or coolant? whats the compression on the engine,,,,,,,,,what percent leakdown does each cylinder have,,,,,,,,does the cooling system pass the pressure test,,,,,,,V8 or 6,,,,,,,I surely can pull that engine and drop it off at an engine rebuilder for you,,,,,,,IF,,,,,,,you are in my area,,,,,,,you might just need valve stem seals,,,,,,,,
    gary h
    gary h
    Number of posts : 497
    Post by gary h Thu Jan 14, 2016 9:28 pm
    My Guess with White smoke may be a Headgasket issue, Has it overheated at some point?
    Post by Guest Fri Jan 15, 2016 3:43 pm
    Thanks for the quick response. As you can tell, I have been on this site for a while but am now getting a bit more serious (now I have more time and money) about getting all the bugs out of my van.  My first and only classic vehicle.
    I am in North San  Diego County, there isn't any issues with overheating, leaking, etc.. with the engine. Starts fine, runs fine, etc..
    I have just talked to the mechanic that did do some work on the van this summer and he "attempted to fix a somewhat warped manifold"?
    % leakdown, pressure test on cooling system, etc.. don't know that. But again, the whole engine runs well and pretty quiet for a 50 year old vehicle.  I have no problem starting the vehicle, taking it out on the street, starting, stopping, etc.. except for the embarrasement of the white smoke.
    I wish I could be more specific but with all this knowledge here on this site, just looking for a little direction so as to when I do attempt to  get the smoke taken care of, I have somewhat of an idea of what I could be expecting.
    Thank for your assistance and for this awesomes site.
    dirtbag69
    dirtbag69
    Number of posts : 34
    Registration date : 2015-07-18
    Post by dirtbag69 Sun Mar 27, 2016 11:05 pm
    Everyone in SD sent me to Rory Fontana in Simi Valley. I had front end stuff, which I had done at Bee-Line in SD (they can't help with the engine). All the guys in SD say Rory is worth it. If you upgrade your AAA, you can even get it towed up and take the train back. I know .. it's far, but he's the best according to everyone.
    https://www.facebook.com/Fontana-Motorsports-198648423567772/
    Number of posts : 698
    Post by Russell Mon Mar 28, 2016 7:56 am
    I have a friend who is a great mechanic and loves a challenge, his shop is in Santee.
    Import auto service, (619) 596-9999 ask for Tim.
    Post by Guest Sat Sep 17, 2016 11:01 am
    Wow, how did I miss this until now. I will definitely give Tim a call. Thanks Russell.
      Current date/time is Fri Nov 22, 2024 7:53 am
