    Broken vent window
    Number of posts : 672
    Broken vent window Empty Broken vent window
    Post by samsvan Tue Jun 23, 2015 2:47 pm
    I was "fixing" one of my vent windows and just when I thought I was done, the stud that holds the chrome locking piece on broke. Is this piece removable? I have a spare vent window but it's from the other side. I've tried PB Blaster and heat but it doesn't seem like it wants to come apart.
    Thanks
    gkpost
    gkpost
    Number of posts : 224
    Broken vent window Empty Re: Broken vent window
    Post by gkpost Wed Jun 24, 2015 9:56 am
    I saw this post yesterday and I happen to be working on replacing the vent window gaskets on my 67. I looked this morning and on the bottom of my handles there is a small roll pin, (very small) if your's is the same you need a very small punch to take that out and you should be all set. Good Luck and hope this helps. ~ G.K.
    Post by samsvan Wed Jun 24, 2015 1:08 pm
    GK, That's not what broke. Once you remove the pin and pull the chrome piece off, there's a notched stud that sticks out from the frame. That's the part that broke. I would love to be able to replace it instead of taking the whole vent window out for replacement.
    Thanks, Sam
    gkpost
    gkpost
    Post by gkpost Thu Jun 25, 2015 4:02 pm
    I'm thinking there is no easy way out of this one. You're probably going to have to take the vent window out. Unless you took the glass out and maybe have the broken part welded?
    It could work. Good luck ~ GK.
    Post by donivan65 Thu Jun 25, 2015 11:42 pm
    I would try pulling the glass out and lifting the gasket and seeing if the stud can be welded back on,,,,,,
    Broken vent window Dscn6631
    Broken vent window Dscn6632
    Post by samsvan Fri Jun 26, 2015 9:02 am
    That's the animal! That stud broke in half. It didn't just pull out. I think they're pressed in so welding is probably my best option. Thanks gentlemen.
    gkpost
    gkpost
    Post by gkpost Sat Jun 27, 2015 9:06 am
    One more thing you may want to look at, now I'm just guessing but LMC has very thing you could want for blazers, suburb's, trucks, and I'm thinking a lot of this small stuff could be the same. If its not its got to be close. might be worth a look! ~ GK.
    AzDon
    AzDon
    Number of posts : 742
    Post by AzDon Sat Jun 27, 2015 9:27 am
    There are "vent locks" available that slip over the edge of the glass....Not really a fix, but would secure the window.......Just be happy that it's not the bottom pivot stud that broke (the one with the spring) This is a common problem with ALL GM wing windows and is near impossible to fix...
      Current date/time is Sat Apr 27, 2024 5:05 am
