by dix Sat Jun 20, 2015 2:36 am
I'd agree it's to high and out of center , i had the same problem , what i did was yank the motor mounts, leave the front fan off ,so you can move the engine left and right with a gas station type jack.
use the jack to lower it and move it left and or right to sit center and near level , then move the engine
brackets around like rod mentioned one in front /one in back till you find what works,
my mounts were to high also, went to napa started looking at mopar mounts, the late 60's or early 70's
valiant mount looks like the right size,I took those home and ground off the small centering nipple.
and it all worked well, the mount turned a little from no centering pin , but it's not a lot, once it moved, it never moved again, that is what worked for me, hope all this helps My mission was to get the engine level, i'm not a engine builder but i wanted to keep the oil where the manufacturer wanted it . every engine you see always sits level,
