Does anyone here have any install diagrams or photos , or suggestions, of the of the V-8 motor mounts in an A-100? I spent the 5 hrs trial and error making them fit correctly, their close but not perfect, I just want to make sure they are correct. Thanks!
A-100 Motor mount location?
Re: A-100 Motor mount location?
Rollie with something like that you want it right, I would just wait till you go to the Nat's and measure a A100 there
My mechanic is e-mailing me this morning as to this problem, as he is in the middle of the install this weekend?
- Number of posts : 8729
Wally can you tell me what the problem is???? also do you belong to a100 groups scottie has photo's posted there. and i have a pair in my garage. let me know...
Thanks a bunch!!!!!!
If you did not cut down the drivers side from the /6 or replaced from a v-8 then it needs done,
Also note that on cars, the engine brackets go behind the engine 'ears'.
On the vans, one is in front, the other behind. I think it's the right that is in front, but can't remember...
jimmyZ- Number of posts : 10
Registration date : 2017-03-11
I AM NEW TO THIS SITE AND WAS WONDERING IF YOU COULD PROVIDE ME WITH THE INFORMATION NECESSARY to cut down the left side bracket. When I got my van I was told they were V-8 brackets never seeing others I took the owner at his word well I am getting ready to put in the 318 and things do not look right the driver side sits too high ,I got 82 dodge truck mounts and 72 dart rubber mounts now I have to look at a complete set for$$$$$ or trying to salvage what I have little $$$ and save my ars for Momma. Thanks for any helpdix wrote:If you did not cut down the drivers side from the /6 or replaced from a v-8 then it needs done,
