Does anyone one know where you can get the inside material that lines the dog house, mine is embarasing!!! , would like to clean up the kennel!!!
gotavan
a-100 dog house liner
gotavan- Number of posts : 242
Re: a-100 dog house liner
I used one of those water heater insulation kits from home depot, the thin aluminum foil backed stuff there was enough to do the sides , lid, and the back for $20. They sell the same stuff for hot rod firewall insulation for a lot more money.
Most guys GM, Ford and Dodge guys use a product like Dynamat, or Cool it or something like those products. For the Doghouse you have to have the high heat material
jkr- Number of posts : 1148
any heating, ac, and ventilating company has some that is almost a perfect match. at least the ones around here do.
Scott- Number of posts : 1651
What's best to stick it to the inside of the dog house? Seems like the spray adhesive would get hot and let go.
if you go to a body shop and get them to weld the stud gun pins on the inside that works great. these are the ones they use to weld on and grind off after pulling dents from metal. i just used oversized speed nuts and then bent the studs over and that helps keep things in place. mine has not moved or fallen down anywhere inside the doghouse.
I've got the same stuff as nate from summit, going to give it a try in the next couple of weeks as I swap the 318 from the parts van into my pickup.
oo3- Number of posts : 290
at all the home depots i have tried they no longer carry the same insulation - i did use the same back when i had the chevy - i found some at a local pep boys for right around 20 - dont know about all years but my dodge has the tabs that you poke thru the insulation and bend back - supposed to have some sort of plastic washers too i believe - oo3
those washers are more like cardboard than plastic, i have used insulitation for duct work at lowes, has the foil back and a roll of that foil tape cleans up the seams nice. cheaper than summit and works well.
