Just got my re-cored radiator back from the shop today! Here are some pictures of my old, original 1964 core, yikes, guy said it was 75%+ clogged and so bad that boiling would not have cleaned it out. Looking at the pictures, I'd say it was worse than that, only a handful of the tubes are clear. No wonder I was running hot all the time. The original radiator was stamped Harrison on the tanks which I found out was a division of GM just like Delco, they made all GM radiators back in the day. The original radiator has 1/2" tubes spaced at 9/16" centers according to the guy at the shop, which BTW was very hard to locate, seems all the new plastic and aluminum throw away radiators have made these shops dry up, most of the old school shops that know how to solder and braze in my area were gone and this place was hanging on by doing commercial trucks and buses, they are a dying breed. The guy suggested that I get it re-cored using a commercial truck grade core, 5/8" tubes spaced at 3/8" which gives 2 rows X 45 = 90 tubes vs. the original's 2 X 32=64 tubes, so, in theory the cooling capacity should be much higher, I won't know until warm weather, months away. But here the pics of the old core and what happens to them after 50 years....
These will make you think....
The shop:
"New" radiator
I'll post some better pics of it after I install it. He did a real nice job, used my tanks and frame preserving the angle of the top tank perfectly, that's another reason not to try to retrofit an aluminum radiator into our vans, the stock radiator sits at a forward angle and the tank is mounted at a bevel to compensate for the cap and in/out pipes are angled as well. Finally, this was not cheap, boiling would have been less than $100, this was close to $400 to have done due to the high cost of copper these days.
The shop:
"New" radiator
