Sway bar mounting Bolts
mexbob- Number of posts : 19
Registration date : 2014-11-15
scarlin- Number of posts : 258
Re: Sway bar mounting Bolts
I added a sway bar last year on my 67 PU. It already had holes in the frame for the bolts, Don't know if a 63 has them. Due to the U bracket about any bolt would work about 1" (25mm) long, I would use a Grade 5. Good luck with the shock bolt removal. The ride is better.
- Number of posts : 2011
The anti-sway bar was optional on all 1961-1967 Econolines, so the holes in the frame are on all of them.
I agree with the 1" and grade 5. It is OK to be longer, since the end of the bolt will be inside the frame.
