I have been having problems with my 1974 Ford Econoline 200. It has a 302 ci, auto trans.
Problem #1 ) When driving. The trans shifts gears from 1st to 2nd at about 40 miles per hour. (should be about 25 to 35).
Problem #2 ) When driving the van cut out on me and just died. It started right back up with out a problem. I was accelerating at the time and she just died. I have changed the fuel pump, changed any rubber (neoprium) hoses, new fuel filter, cleaned out the gas tank, repaired it as well, changed the pickup filter, changed the carberator, and blew out the lines. When I step on it it goes. Just with no warning died out. I checked the timing and it is ok. Next thing I am going to do is pull all the plugs. Change them all. Check the wires for continuity, check the cap, router, condenser. After this, I do not know where to go if it still is occuring. Any ideas anyone?
