    A van driveshaft trunion, replace or alter shaft?
    MikeE
    MikeE
    Number of posts : 18
    Registration date : 2013-03-21
    A van driveshaft trunion, replace or alter shaft? Empty A van driveshaft trunion, replace or alter shaft?
    Post by MikeE Mon Nov 10, 2014 9:45 am
    Buying a 108 2 thousand miles away, flying in to drive it home. Present owner says old "trunion" set up is worn out. Do I need to find a 108 drive shaft with u-joints? Will it be direct replacement? Best way to go? I have a 108 at home but the drive shaft has u-joints at both ends so I can't get a good idea what trunion set up looks like. Could just ship the 108 shaft I have here to where other van is at. If I need a piece or 2 to have trunion replaced and someone has them let me know.
    Thanks, Mike
    Number of posts : 8770
    A van driveshaft trunion, replace or alter shaft? Empty Re: A van driveshaft trunion, replace or alter shaft?
    Post by dix Tue Nov 11, 2014 3:37 am
    you would be better off finding a driveshaft company near the location of your new van drive it there , remove it & have them build a brand new one for $250. /$300. and then drive it 2,000 miles back home,
      Current date/time is Mon Nov 25, 2024 5:45 pm
