docmcg
    Rear spring shackles
    docmcg
    docmcg
    Number of posts : 206
    Registration date : 2014-09-08
    Rear spring shackles Empty Rear spring shackles
    Post by docmcg Thu Oct 16, 2014 1:12 pm
    I have reason to believe there was prior rear end work done on this truck. When I first got it the rear sat quite high. I think someone reversed the shackles. Can someone tell me if the spring in the back is supposed to go above the the perch or below it. What I mean is, does the shackle hang down or point up?
    Number of posts : 8769
    Rear spring shackles Empty Re: Rear spring shackles
    Post by dix Thu Oct 16, 2014 3:12 pm
    the spring should be above the perch
    Scotts_A100
    Number of posts : 160
    Post by Scotts_A100 Thu Oct 16, 2014 6:21 pm
    The following shows the spring hanger position on the rear axle as I was working on the brakes. Hope that this helps. Scott...
    (PS you may have to double click on the picture to see the whole picture.)
    Rear spring shackles Brakes10
    Post by dix Thu Oct 16, 2014 7:01 pm
    great pic scott,
    docmcg
    docmcg
    Post by docmcg Thu Oct 16, 2014 9:17 pm
    Thanks Scott, except I can't see the rear shackles in your picture. I changed the position of the shackles so they point up above the spring. Truck now sits lower (obviously) and the pinion angle looks less severe than before.
    busman78
    busman78
    Number of posts : 483
    Post by busman78 Fri Oct 17, 2014 5:10 am
    Here is another shot of the rear shackle
    Rear spring shackles Img_0117
    docmcg
    docmcg
    Post by docmcg Fri Oct 17, 2014 8:18 am
    Thanks, Busman. That's exactly what I was looking for. As I stated earlier, my shackles originally mounted pointing down. I didn't think that was right, especially because of the pinion angle. I mounted mine like yours, and now all is right. Thanks again, I really appreciate your time.  Steve
    Number of posts : 957
    Post by slowflapper Tue Oct 21, 2014 9:21 am
    docmcg wrote:Thanks Scott, except I can't see the rear shackles in your picture. I changed the position of the shackles so they point up above the spring. Truck now sits lower (obviously) and the pinion angle looks less severe than before.
    I'm surprised you haven't been blowing out the rear u joint. I had my spring bushing replaced once and the shop put the shackles in upside down by accident, rear ujoint didn't last 100 miles before it went.
    I think permissible pinion angle is 5 degrees or less depending on rpm.
    more details on that
    Number of posts : 14778
    Post by vanny Tue Oct 21, 2014 9:41 am
    Busman, I never thought I'd say this to another Guy but you have a nice clean rear end! Is that rear disc brakes as well?
    busman78
    busman78
    Post by busman78 Tue Oct 21, 2014 10:17 am
    Why thank you, it got a little scuffed up during the install. Rear was media blasted and painted with Eastwood Chassis paint. Yes indeed it does have disk brakes, also notice that is a Ford 9", the 8-3/4 Mopar can be seen in the background.
    Post by vanny Tue Oct 21, 2014 5:27 pm
    Nice, I bet it stops on a dime now! Looks Great! Very Happy
      Current date/time is Sun Nov 17, 2024 7:39 pm
