    Rear drum spring hardware
    Number of posts : 533
    Rear drum spring hardware Empty Rear drum spring hardware
    Post by Van crazy Tue Jun 24, 2014 7:03 pm
    I could not find a home for these 2 "c" clips any suggestions on were they might go. I see my van had no adjuster holes either...Rear drum spring hardware Brake_10
    Number of posts : 12245
    Rear drum spring hardware Empty Re: Rear drum spring hardware
    Post by donivan65 Tue Jun 24, 2014 7:37 pm
    Well since our vans don't use rubber adjustment hole plugs or C Clips, I would say you might have  the wrong hardware kit,,,,,,,does everything seem right?
    Rear drum spring hardware Repair24
    Post by Van crazy Tue Jun 24, 2014 7:54 pm
    It looked like the adjuster spring was larger on the front drums but it looks the same size as the one in your pic.There was a right and a left spring I got that right so as it clears the screw part. There was the 2 springs that hold the shoes on one was longer than the other I put the longer green one on the side without the adjuster it seemed to make sence. As it is it seems right to me.Rear drum spring hardware Rear_d10
    Post by donivan65 Tue Jun 24, 2014 7:57 pm
    just make sure the spring that goes over the star wheel does not touch the wheel,,,,,,they are easy to mix up,,,,
    Post by Van crazy Tue Jun 24, 2014 8:05 pm
    cool ya I noticed that... It dont touch I was stumped for a second when looking at the parts they were different colors I thought I was missing the spring for the other side and then there it was. silly me... Thanks for the help donovan I was hoping you would pull threw.
    Post by donivan65 Tue Jun 24, 2014 8:29 pm
    there are a lot of different kits,,,,,some are springs, some are the star wheel and self adjusting parts,,,,,,the front shoes are 1/2" wider than the rears,,,so they take longer hold down spring pins,,,,,but as long as you had to pull a little bit to get the springs to stretch and the hold down springs keep the locking disks from turning, things should be OK.....
      Current date/time is Sun Nov 17, 2024 5:35 pm
