I picked up a van from a member here, Anthony aka Dose, a couple weeks ago. Put in a radiator and drove it home 150 miles. With no problems, more or less. But it wasn't running well so i went to the parts store for tune up stuff. On the drive home, it was backfiring through the exhaust quite a bit and it felt like it was only running on 7 cylinders (318/auto). I assumed that the dead cyl was letting gas through to the exhaust. blah blah blah..... this could get long....
To make this long story shorter, the carb floats sunk and was dumping gas into the manifold. So the carb has been rebuilt and new floats installed but the throttle is sticking. Its not the carb, its the cable. the cable is brand new. I didn't lube it at all before installing it. Figured that was done during production and I've loosened up the clamps at both ends to rule out binding. Do I need to pull it back out and run some light oil down it? or has someone else run into a similar problem and come up with a fix?
thanks
thanks
