What is the secret to removing the lite switch & Ignition from the DASH ? I have the cylinder out of the ignition body but I cant seem to make any further progress.
stanyon
Lite Switch
stanyon- Number of posts : 147
Lite Switch
- Number of posts : 2016
Re: Lite Switch
The ignition switch disconnects from the round bezel with a spring-loaded bayonet connector. This is similar to the turn signal lamps. You have to press the body towards the dash and turn it a little. It can be stubborn.
There is a button on the side of the light switch, which when pressed, allows the knob and shaft to be pulled all the way out.
- Number of posts : 12248
Re: Lite Switch
Re: Lite Switch
Disconnect the battery our you may light yourself up. Lots of hot wires in that location.
Re: Lite Switch
THANK YOU, THANK YOU, THANK YOU, BARNABAS.
FCC- Number of posts : 295
Re: Lite Switch
Timely post, I believe I lost a fuse. My radio and interior lights are not coming on.. are they on the same one? Is this the best method for getting to them?..just pulling the whole switch from the dash?
- Number of posts : 2087
Re: Lite Switch
I had to change one, managed to do it in the dash, you're in for treat. I getting a new fuse block when I can get to it.
Re: Lite Switch
yeah.. dash skirt too.
Re: Lite Switch
Here is a pic of the ignition switch. Notice the big spring that you have to push against to get it to turn. Notice the little bump in the top left corner. There is another on the opposite side. These two bumps line up with the bezel and twist into place.
Here is the bezel where you can see where the two bumps in the ignition switch line up.
Re: Lite Switch
I got both removed and out of the way to-day, really know problem when you have the combination. Thanks again Barnabas
