67 A108, the front studs were pressed out, purchased Moser 8368 1/2-20 .625 knurl studs which can be pressed in with my thumb. Too loose to run the way they are, so would .625 knurl studs from ARP or Dorman be a tighter fit? Ideas as to a safe fix besides replacing the hubs would be appreciated.
+4
tdc
busman78
8 posters
Wheel Stud Dilemma
Wheel Stud Dilemma
Re: Wheel Stud Dilemma
Nothing was ground, they just pressed pressed them out.
if the old ones are now loose,,they wrecked the hubs,,,,,,when they put in the studs, they swedge the studs to hold the drum on,,,,,that swells the end of the studs,,,,,so they end up bigger than the hole on the hub that they just came through,,,,,you got to grind it smaller to pass back out and not rip out the serrations that are now in the hub,,,,,,I would not put loose studs in,,,,they will spin when you try and get the lug nut off,,,,,,maybe a Dodge guy can tell you if there is an oversize repair stud available,,,,,I guess you could put a big bolt in there and take the hub and drum off each time to get the wheel off,,,,,,,,
It is getting a Scarebird conversion with Wilwood calipers, no more drums
ok -if no oversize studs are avail?? consider bolting a wheel on TIGHT!! & spot weld the stud on the back in a couple places.
tdc- Number of posts : 32
Registration date : 2014-03-10
Yeah, I was going to suggest welding them in the back too. It is definitely not ideal, but would get you by until you could get things fixed proper. We had to do this on an old Dart for a summer.
Sounds like you have a better plan now anyway!
- Number of posts : 8731
THE 6.25 IS THE CORRECT SIDE , LIKE DONNIE STATED SOMETHING HAPPENED,
Not thrilled about welding, been researching Dorman (not thrilled about Dorman either) but they have 1/2-20 x 1-21/32" with a .630 knurl, that would be .0025 on the radius, might make for good squeeze.
You could weld inside the holes. Just three small spot welds in a triangle pattern. Then the studs will fit tight and be removable.
econopoor- Econoline Guru
- Number of posts : 1747
I picked up some slightly oversize studs from Oreilly's They are 1/2-20 with a .641 knurl and 1 9/16ths long. Just that little bit extra knurl for a good tight press in fit. Part number Dorman 610-085
Thanks, just called O'Reilly's to get a box, pick it up this afternoon. Possible salvation.
dodge A-108- Number of posts : 67
I welded mine to the back of the hub. no problemsbusman78 wrote:67 A108, the front studs were pressed out, purchased Moser 8368 1/2-20 .625 knurl studs which can be pressed in with my thumb. Too loose to run the way they are, so would .625 knurl studs from ARP or Dorman be a tighter fit? Ideas as to a safe fix besides replacing the hubs would be appreciated.
