IS THE FUEL TANK THE SAME FROM 1ST GEN VANS TO 2ND GEN VANS
66 7 67 FUEL TANK
ALLZS- Number of posts : 43
Registration date : 2014-05-04
66 7 67 FUEL TANK
Re: 66 7 67 FUEL TANK
No.
First gen is a smaller,12 gal. tank.Second is a larger 22/24 gal. tank.
First gen uses a 30 Ohm sending unit,second gen uses a 90 Ohm.
BUT....you can move the cross member forward and fit the larger tank.
Several folks have.I'm sure others can give you better direction on this,I haven't done this before.
Welcome to Vintage-Vans.
Space Truckin- Number of posts : 1279
Actually 67 is 16 gallon, the larger tank did not make it in till 68
Thanks Truckin.I get confused on my vehicles around here.
